Timing /Log Not matching up
Posted: Wed Sep 05, 2007 8:34 am
by Phantomhatch
The main problem is i have set my map to about 15* at full boost but it is logging 27!
I have checked the following :
1) Ign comp - air and water
2) made sure the timing on the car was correct and set base timing
3) tripple checked physical timing
4) made sure it was in open loop
-- it only seems to happen in the map where posative pressure is introduced
I also tried setting up a boost map to see if timing is taking away as well Still says the same
- also another strange thing is i am boosting 15psi and have 880cc injectors and they are MAXed in the log at 104 duty. and my fuel in the high en is close to 5000 . this is just to get the Afr to around 11.8
Any ideas would be great on the timing :) thanks
Re: Timing /Log Not matching up
Posted: Wed Sep 05, 2007 8:48 am
by boostedcivicsir
well i am not god and they are gonna ask for the log and the cal any way so start there, and see whats up. post that so we can see whats goin on.
Posted: Wed Sep 05, 2007 10:50 am
by Phantomhatch
the Log
Posted: Wed Sep 05, 2007 10:51 am
by Phantomhatch
current map
Posted: Wed Sep 05, 2007 11:01 am
by boostedcivicsir
again i am not god, still learning this myself, but if you look at the log over the tables, the thing i saw was ect was close to 200, so there was 3-3.5* timing pulled up top. never saw the timing peak at 27* at full boost. where you are seeing that is low boost/vac between shifts.
at your peak boost of 16.6 psi, timing was 17* should have been 21.25* ect was 199.2*F and thats where hondata takes timing away. (is there a fix for that yet?)
wait til spunkster or someone looks at it too.
as far as your injectors being 104%. idk whats up with that. how is the condition of the fuel system?
Posted: Wed Sep 05, 2007 1:04 pm
by Phantomhatch
As for the Temp being 200* in the ign. comp tables there is nothing to be added or removed above 168*
As for the fuel system i have a sumped tank with a aeromotive a1000 pump and -8 line going to the rail and a aero FPR and the FP is set at 45psi with vaccume
im lost
Posted: Wed Sep 05, 2007 1:07 pm
by boostedcivicsir
i was talking to my tuner about the temp correction, it still pulls timing up there. atleast it did on my car as well.
what are the plugs looking like when you make a pull?
Posted: Wed Sep 05, 2007 1:50 pm
by Phantomhatch
The plugs look slightly white not white full blown white .. noting to indicate too lean or to hot.
i might just go pull one and take a pic
Posted: Thu Sep 06, 2007 8:06 pm
by Tchleung
So what's the problem exactly? Your logging more IGN timnig then the maps say? Cause not for me it doesn't. I downlaoded your tune with the log and it's dead on. If not reading a bit lower then the maps.
PS: boostedcivicsir, what's with all the I am not GOD? I thought it was a typo at first, but you said it a second time lol
