b16 engine 9:1 comp. New internals, obd1 conversion, Wiring has been rechecked, Fuel pressure set to 42 psi running mitsubishi evo 560cc injectors (resistor box) motorola 2.5bar map. running stock p30 map on s300/p28 ecu in 91 civic.
Crank engine, fires up for a split second, rpm goes to about 325 on the datalog and dies, plugs are wet, and I am getting spark, compression ~160 dry across the board. I set the fuel trim for 560cc injectors.
I'm very worried about washing out my rings and ruining this brand new engine. I have no other car to try the ecu in and the only stock part I have left to swap would be the stock map sensor.
Someone please help me before i ruin my engine.
no start, s300, freshly rebuilt engine. HELP!
jayjay6611
Phantomhatch
jayjay6611
Phantomhatch
jayjay6611
Re: no start, s300, freshly rebuilt engine. HELP!
jayjay6611 wrote:motorola 2.5bar map.
jayjay6611
Preccord00
