Need help with the K-Pro
Posted: Mon Sep 03, 2007 2:50 pm
by WilsonC
Hi.. i haven't purchased this product yet but i'm planning on getting a k-pro.
i'm just really confused about how this works... I send in my ECU then they reflash it?? and add some stuff??
can someone explain to me how this k-pro thing works..
i know i should read the site.. i've read it many times.. some how i'm still not getting it.
Posted: Tue Sep 04, 2007 10:45 am
Is your question about the reflash, or the K-Pro....they are 2 separate things?
Posted: Tue Sep 04, 2007 5:31 pm
by WilsonC
i guess both the Kpro and the reflash..
Posted: Wed Sep 05, 2007 5:55 am
by FrequentFlyer
If you want the reflash, you have to send your factory ECU, immobilizer and key to Hondata and they will reprogram it with a modified map. This is a one time deal and basically a 3 day process. Overnight your ECU to them, they get it and usually reflash and send it out overnight the same day. So, you're without an RSX for about 3 days.
The Kpro is a user programmable ECU. If you have an '02-04, you will have to send in your ECU much like the reflash, but there is more labor involved as they physically modify the ECU to communicate with a PC via USB. If you have an '05-06, you will need to buy an '02-04 ECU (preferably used to save $$) because the '05-06 ECU cannot be modified into a Kpro. You will also need an '02-04 O2 sensor for this to work.
So again, the reflash is a one shot deal and the Kpro pretty much gives you endless tuning possibilities.
Posted: Thu Sep 06, 2007 5:03 pm
by WilsonC
I see so.. overall if i don't mind spending money for endless tuning i should go with the K-Pro.
The reprogramming part... I get the program and is it stupid proof?? Are there guides? or do i have to get some hondata expert to come and tune it?
Posted: Fri Sep 07, 2007 9:17 am
Download the software and check it out then you see exactly how it works. It is in the download section of the website.
