Turbo Kit w/ K-pro
Swoopep3
Turbo Kit w/ K-pro
Post by Swoopep3 »
I just bought a Rev Hard turbo kit w/ k-pro, Im about to send the ecu to hondata and not sure if the ecu will need to be tuned right when it is put back into the car. Is k-pro pre-programmed to run untuned?
You will have to upload the base map you wish to use, then tune it on the dyno.
Swoopep3
Post by Swoopep3 »
Im just wondering if the car will be drivable until I can afford to have it dyno tuned.. I dont plan to run it hard until I get a new clutch and dyno tuning anyways.
You will have to upload the basemap you wish to use then see how your car runs from there.
