Datalogging problem when engine is running
Posted: Thu Aug 23, 2007 8:39 am
I am retuning a car that I did 6mths ago. I didn't have any problems then. I can not real time log or upload when the engine is running for longer then a second but I can upload files, download datalogs when the key is on but engine is off. The lights start out normal flashing green and orange then when it freezes they go solid.
The things that have changed that i am aware of from last time:
went from a gm 3bar to a aem 5 bar map
switched out the manifold and turbo
installed autometer egt gauge
I put in the gm boost solenoid
in trying to diagnose the problem I have tried:
switching from the r5671a-9 spark plugs to a bkr7es-11 for the resistor
switching out the ECU and S300 for mine (known to be working)
switching from my normal dell (i use all the time without a problem) to a toshiba laptop
2 diffrent usb cables
unpluged the boost controller
unpluged the egt
checked and fixed a ground at thermostat
Im pretty sure its something with the car more than the hondata but I could really use some input.
unpluged the egt
