vss need help
Posted: Wed Aug 22, 2007 11:36 pm
by vivalive
i have a 05 base rsx k20a3/5 speed.
what percent should i set the speed sensor correction?
Posted: Thu Aug 23, 2007 12:06 pm
The correction is more for different tire sizes, not the difference form the type S to the base transmission gearing. You can make some adjustments, but it will more than likely always be off by a little bit.
Posted: Thu Sep 06, 2007 7:29 pm
by vivalive
i found this under help files.
05 will be in OBDII all the times doesn't matter if i uncheck "OBDII Enable"??
Misc Parameters:
Countershaft driven speed sensor - check this option if using a transmission with a countershaft driven speed sensor (e.g. 2005 RSX). The ECU will then convert the pulses from the speed sensor to the correct frequency for the gauge cluster. Note that enabling this option will automatically disable OBDII functions.
