vss need help
vivalive
vss need help
Post by vivalive »
i have a 05 base rsx k20a3/5 speed.
what percent should i set the speed sensor correction?
The correction is more for different tire sizes, not the difference form the type S to the base transmission gearing. You can make some adjustments, but it will more than likely always be off by a little bit.
vivalive
Post by vivalive »
i found this under help files.
05 will be in OBDII all the times doesn't matter if i uncheck "OBDII Enable"??
Misc Parameters:
Countershaft driven speed sensor - check this option if using a transmission with a countershaft driven speed sensor (e.g. 2005 RSX). The ECU will then convert the pulses from the speed sensor to the correct frequency for the gauge cluster. Note that enabling this option will automatically disable OBDII functions.
