Small bug/enhancement requests for k-manager
Posted: Wed Aug 22, 2007 6:55 am
Found a few small bugs when using k-manager. Some are very small wish list type of things and some could be really useful when editing maps.
1) Pressure is displayed in different formats in quite a few places. Would be nice to have one place to set units for the entire program.
2) When analyzing datalogs and looking at the lambda and deltas, if you highlight the cells and paste them elsewhere, you get the fuel tables values, not the lambda values that are currently being displayed.
3) Check (x,y) coordinates of window on startup to make sure they are on screen. Looks like k-pro tries to go back to the same place that it was last used. I use dual monitors at work, and had k-manager on the 2nd monitor. I'm using the same laptop that night at home to datalog. I startup k-manager and it doesn't show up because it started up at an (x,y) that doesn't exist anymore. Fortunately I was able to crank up my screen resolution enough that I was finally able to grab the corner of k-manager and drag it back into a useful range. Only other option would have been to find the registry entry or .ini file and modify it by hand.
4) Would be nice to have cam angle in the display.
5) When looking at graphs for datalogs, would be nice if you could select thickness of graph lines. Would make it much easier to see the color of your lines and tell them apart.
6) Audible beep from laptop under different conditions. For example, set a beep if a/f goes above X:1. Keeps someone out driving/datalogging from having to keep an eye on the laptop while they drive.
Just my $0.02
Just my $0.02
