P29 ecu, will it accept an S300j?
doo0T!doo0T!
Post by doo0T!doo0T! »
I have a square case jdm P29 ecu which is out of an EG5 1600cc dohc non-vtec and it is obd1.
Can an S300j be installed on this ecu? And if it can will it allow for the full range of hondata functions? (excluding boost control)
Heres a pic of the inside.
-JDM EF7-Si CRX ZC/d16a6 hybrid turbo
-JDM EG5-Si hatch with H22a swap
-JDM EJ7 coupe, evo H2B with H22a-EuroR
This ECU looks like it can be used. More than likely it supports the same outputs as the P08
