changing in injector size
alexsracing
Post by alexsracing »
under parameters > fuel trim
old settings stock 240 , current 440
I changed it to stock 240 , current 1000
the fuel tables stay the same , do I have to scale it myself?
2001 Acura Cl
1994 Civic CX SFWD in the works
No, the fuel tables are adjusted by the injector size, so they should not change.
fuel trim does not change the fuel tables. Tables will have to be changed to suit the needs of the flow characteristics of your specific injectors.
alexsracing
where do I go to change to rc 1000cc injectors
2001 Acura Cl
After changint he setting in fuel trim, you will just have to begin modifying the fuel tables. You need a wideband to be able to read the AF ratios.
alexsracing
ok, I have a plx m-500
just thought it would do an auto adjustment so I don't have to guess the startup fuel portion of the map
2001 Acura Cl
platinum00
Post by platinum00 »
Is there default multiplier you can use for each size injector, or do you just keep increasing until you get your desired A/F.
What does changing the injector size do if it does not change the fuel tables?
platinum.
Changes to the injector size make invisible changes to the overall fuel trim.
