Do I need to use dyno?
I have an s200 that does not work at this time I think its a bad chip. The place where I bought it says they need to take out my car and tune it on the street with wideband. They said that they need to do this cause you can only tune under full throttle on the dyno. Can I tune the whole thing on the dyno? Thanks
Typically you don't *want* to do part throttle tuning on a dyno, because the price per hour is higher than having a tech ride around in the car. It's more economical to do the part throttle tuning on the street, and save the dyno for WOT.
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
The starting maps are just that...a starting point. Every car is different. A map that worked perfectly in one setup might be slightly off in another.
I drove around for over a year before getting my part throttle tuned correctly. It made such an enormous difference in the drivability of the car that I almost feel it should be a requirement for purchasing the system.
'99 EBP Si
