Not the common issue
gorgon2k4
Post by gorgon2k4 »
Ok guys, 06 type-s. its not so much my idle.. if it sits... it idles fine.. its when i depress clutch.. it will dip, sometimes when i depress clutch idle will hang, even putting my windows down cause the idle to jump a few hundred rpms. sometimes it will hang around 1500 for a few secs, and sometimes it will dip down to like 650-700. my idle is set at 900. it never did anything like this before k-pro so that makes me think its not a vacuum leak. but i still will check. i did the cleaned the IAC, no help, and also made the adjustments in K-PRO, i.e. cam angles, ingnition etc. adjusting the slider doesnt do much except make it worse on way or another.
gorgon2k4
Post by gorgon2k4 »
- serial number of your K-Pro- 3851
- the calibration (as an attachment) h/o
- a datalog of a problem (as an attachment) h/o
- what sort of vehicle you have- 2006 acura rsx type-s
- what sort of ECU you are using- 02-04 PRB ecu
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
Injen CAI, T1R 63mm exhaust, Buddy Club RH, ingalls TD, ESMM
- a specific description of the problem
LISTED ABOVE
