Changing from obd2 to obd1 ...newbie question
Posted: Mon May 26, 2003 12:35 pm
by GR8GRIBBS
before getting hondata, is it a must that I convert to obd1, or can I run my stock ecu?
I have a 99 honda prelude.
Posted: Tue May 27, 2003 5:24 am
by AndyE
If you have an OBD2 vehicle, you'll need to move to OBD1. The steps go something like this:
1) Buy preconfigured Hondata OBD1 ECU (typically a modded P28) from a Hondata dealer.
2) Unplug OEM OBD2 ECU, place on shelf/sell on eBay/use as paperweight
3) Plug in Hondata OBD1 ECU with OBD1-2 adapter harness (or use Hondata-modded OBD1 ECU that already has OBD2 plugs)
Posted: Tue May 27, 2003 12:27 pm
by GR8GRIBBS
If I have bought a p72 from a 94 gsr... can I just buy the hondata program and have a authroized dealer install it in my area, or do I need to send ecu into hondata
I plan on using the s200 program
Posted: Tue May 27, 2003 1:23 pm
by AndyE
An authorized dealer should be able to make the modifications to the ECU. A good dealer will be a one-stop shop.
