JDM Honda Civic FD2 Type R
FD2R_HKG
Post by FD2R_HKG »
I have heard rumor Hondata has worked out a flash program for this vehicle, true or false?
False.
FD2R_HKG
Post by FD2R_HKG »
OK, will there be any possibility to have the ECU flashed by Hondata in the future?
LeeH
Post by LeeH »
FD2R_HKG wrote:OK, will there be any possibility to have the ECU flashed by Hondata in the future?
Bump for this question :D
There may be a reflash in the future, but as yet there is no timeframe.
FD2R_HKG
Post by FD2R_HKG »
I think the hardest thing for Hondata is they have no car to use as guinea pig!
chris2000
Post by chris2000 »
FD2R_HKG wrote:I think the hardest thing for Hondata is they have no car to use as guinea pig!
I'm sure people like yourself and myself is more willing to let Hondata to use and test as well. I know we are very far away from USA but it is ok. :P
Which part of HK are you? I was in HK this during CNY and i don't see many hondas there anymore. Only evos and rex.....
FD2R_HKG
Post by FD2R_HKG »
I am in the HK side. Yes, there are less Honda because of the pricing is not as attractive as Toyota and other brands.
chris2000
Post by chris2000 »
Hi
Just noticed that there is now an ecu for the european CTR FN2R.
Just wondering if there will soon be any for us lonely JDM CTR FD2R ? :cry:
Chris
august77
Post by august77 »
actually.. there is a Hondata reflashed ECU for FD2R in Singapore now.
FD2R_HKG
Post by FD2R_HKG »
Wow, that's interesting to see!
Can someone from Hondata confirm this news? Thanks!
august77
Post by august77 »
Here's the Hondata reflashed ECU for FD2R.. You won see it in Hondata website for now, but maybe in a few months later.
This one just arrived from Singapore and tonight I will be installing it onto my fren's FD2R.
FD2R_HKG
Post by FD2R_HKG »
Please try to post its dyno run result, thanks!
august77
Post by august77 »
Dyno was done on a dyno dynamics dyno, so generally, hp figures are a little lower.
This will be good for mild mods like intake, header and exhaust. Improved maps and optimized over stock maps.
Also features all the new technologies that Honda has put into their new ECUs, like knock adaptation, close loop control, etc.
Has lowered VTEC point to 5100rpm and a higher rev limit to maximize breathing potential of the new FD2 type R RSP head.
Fully plug and play. 5 mins installation and you are good to go!
Fully compatible with standard Drive By Wire.
Allows for speedometer reading above 180km/h.
Complete ECU replacement for easily reverting back to stock in future.
FD2R_HKG
Post by FD2R_HKG »
When you say "Dyno was done on a dyno dynamics dyno, so generally, hp figures are a little lower. ", how much lower when you compare to say Dynapack?
