IACV help needed
Posted: Tue Jul 31, 2007 10:30 am
by jordancivic
Hi guys, im having major problems finding an IACV that works, i have 4 here and none of them work at all, or i have a wiring problem. B16a2 w/s300 btw
Can someone confirm for me what i should expect to see at the plug when disconnected, ignition on:
between pins - 0v
Positive pin - ground 12v
Now this tells me that there is a wiring problem? shouldnt i see voltage between pins with ignition on? im guessing the ecu switches ground to operate the IACV, but it should be voltage surely?
Any help appreciated
Posted: Tue Jul 31, 2007 1:47 pm
It is duty cycle controlled. Are you getting IACV errors? You may need to follow the helms manual for trouble shooting this problem.
Posted: Tue Jul 31, 2007 2:49 pm
by jordancivic
Idiot mistake, 2 plugs the wrong way around. Thanks, thought it would be duty cycle controlled.
