Problem with Datalogging
Posted: Thu Jul 26, 2007 11:59 am
by Joelspy70
I was trying to do a datalog yesterday but half way through the datalog it kept loosing the usb connection and would stop. I tired a different laptop, and a different usb cable with the same problem. It has worked fine before. I am woundering if this is an issue with the port on the ecu? Can hondata fix this if it is?
Posted: Thu Jul 26, 2007 12:31 pm
What spark plugs are you using? What vehicle is this in? What version of software are you using from Help, About?
Posted: Thu Jul 26, 2007 8:12 pm
by Joelspy70
Car: 03 Rsx type S k20a2
Spark Plugs: NGK-BKR7EIX
K Manager Version: 1.2.2.6
Posted: Fri Jul 27, 2007 9:29 am
What has been done to the vehicle?
Posted: Fri Jul 27, 2007 10:41 am
by Joelspy70
Spunkster wrote:What has been done to the vehicle?
Greddy turbo kit and FMIC at 10 psi
Test pipe
3" cat back
Just installed new motor mounts
Posted: Fri Jul 27, 2007 12:22 pm
Have you properly relocated the ground? Are all the grounds still in the proper location and corrosion free?
http://www.hondata.com/techk20ground.html
Posted: Sat Jul 28, 2007 11:47 am
Also check the wiring where is passes behind the turbo. The heat from the turbo hardens the copper in the wiring and it eventually fractures.
Posted: Sat Jul 28, 2007 4:49 pm
by Joelspy70
Spunkster wrote:Have you properly relocated the ground? Are all the grounds still in the proper location and corrosion free?
My engine ground is still on the intake manifold. I will try moving it to the valve cover.
