idle problem
Posted: Sat Jul 21, 2007 1:16 pm
by quickaccord93
Hi
I just want to know if there is a way to raise the idle speed with the s300
The big problem is, when it's cold, I need to push a little the gas pedal, the warm up the engine, if I dont do that, the idle speed is 500 rpm and it's stall
I have a trottle body obd2 with no fast idle and no ajusting screw (came with my h23a VTEC 2000)
The h23a came with a 3 wire idle valve, now I have a 2 wires IAC
In smanager, I try 900 rpm to 1500 rpm for the idle, no change
Thank for your help
Posted: Mon Jul 23, 2007 10:00 am
If there is no idle adjust screw, you may need to find a different throttle body.
Posted: Tue Jul 24, 2007 11:38 am
by quickaccord93
thanks for your answer :D
do i need a fast idle valve if I only run the car at summer
Posted: Tue Jul 24, 2007 12:03 pm
Fast idle valve is not needed, but may need to be fully blocked off as sometimes they fail in the open position.
Posted: Wed Jul 25, 2007 8:53 pm
by quickaccord93
ok thanks :)
