Help setting idle mixture settings Also target Voltage
Posted: Fri Jul 20, 2007 11:37 pm
ok I have a very wierd problem I can't figure out.
I have an H22a4 in BB6 basically stock expect a few minor bolt ons
now heres the problems I went thru the settings to set the idle speed and when I plug in the IACV and clear the code my idle only goes up to 750 then slowly climbs it's way to 800, now when I adjust the IAC duty cycle I can't ever get it to stop at 850 when I let off the throttle it always dips down to like 780 then raises up to 900 then finally settles at 850 after a few seconds.
also when trying to set the idle when my fans kick on the idle jumps around a tad into high pressure coluums then settles back down, when I turn on my JDM fog lights my short term fuel trim always changes by -3
also the car will not idle at 14.7 the closest I can get it is 15-15.1 in closed loop
right now the closed loop target voltage is 0.47
can any lead me in the right direction on how to set the correct fuel mixture for when the car is idling? right now all my fuel comp and ignition comps are set how they have it in the help files for the S300
The car idles fine and isn't dying out or anything it's just that when I check my Long term fuel adjustments it's always at like -4 after a few days in closed loop, I've been lead to believe that this should be 0%
thanks for your help in advance sorry there is a lot of questions I just finally was able to get a login(never got the e-mails on all my accounts) so I've been trying to firgure this out for a while.
