A/C wiring??
yeung22
A/C wiring??
Post by yeung22 »
I've read in some other posts that to get k-pro to control the a/c system I need to make 3 changes in the ecu and then connect the vtp (b9) to the acs
According to this schematic I need to connect b9 to a27. If I cut and connect these wires then the a/c system will work properly right?
yeung22
Post by yeung22 »
Well I just tried it and it didn't work. The compressor clutch didn't come on. So I tried hooking up the acc wire (a17) to the same b9 and it worked. So with a17 and a27 both hooked up to b9 things seem to be okay.......Just a question though, by doing this am I bypassing the thermostat or pressure switch? Will by compressor cycle on and off?
You need to identify which vehicle each pin belongs to.
It should be Civic A17 to RSX E18 and Civic A27 to RSX B9
yeung22
Post by yeung22 »
Hondata wrote:You need to identify which vehicle each pin belongs to.
Well, like you say I guess I need to hook up the Civic A17 to RSX E18 and Civic A27 to RSX B9. The problem is is that the Hybrid-Racing Harness doesn't have a pin out for E18. I'm going to have to find a connector at Radio Shack or something to put in it's place I guess.
bossman032
Post by bossman032 »
so has the problem been fixed? :?:
yeung22
Post by yeung22 »
yes sir, I pulled a pin from a spare connector and added it to the hybrid harness. The A/c works great. Thumbs down to hybrid for not putting the pin in place......
bossman032
yeung22 wrote:yes sir, I pulled a pin from a spare connector and added it to the hybrid harness. The A/c works great. Thumbs down to hybrid for not putting the pin in place......
I have a dc2 hybrid kit. you think I will have to do that also?
I wired up the relay already but my compressor always stays engaged, when I turn on my ac..
anyways how cold is your vent temps? my 89 si r12 blows about 40 degrees in about 98 degress. I haven't got my dc2 ac system completely charged yet.
yeung22
Post by yeung22 »
I haven't charged mine that well either, so mine won't pull the temp down to 40 degrees yet.......I will have to check to see if the compressor will cycle after I fix that.
bossman032
yeung22 wrote:I haven't charged mine that well either, so mine won't pull the temp down to 40 degrees yet.......I will have to check to see if the compressor will cycle after I fix that.
ic let me know how it works out. hopefully if u have no leaks it should be good. :twisted:
bossman032
have u got the system charged and working yet? :P
bossman032
any updates?
