Bug in RomEditor
G3-TEG
Bug in RomEditor
Post by G3-TEG »
Just noticed this today, if you highlight a section of any table to make a change by pressing "J", make a change, then click on "EDIT -> UNDO" and then try to change the same highlighted area again, it will default to the previously changed values you made prior to the UNDO...
Kind of hard to explain, you just have to do it and you'll see what I'm talking about.
Not really a big deal, but it gets anoying after a while.
jag
Bug in RomEditor
Post by jag »
I had a similar problem where there was one column that it wouldn't let me edit in the fuel map. It would just change the values back to the previous values. I eventually ended up exporting my maps to a CSV file and then importing them into a new ROM and it fixed the problem.
-Jeremy
ROM Editor undo bug
Yes, that's a bug. If you have problems with this either don't use undo, or save the rom often. We've fixed it for ROM Editor V3
JT
Re: ROM Editor undo bug
Post by JT »
Hondata wrote:Yes, that's a bug. If you have problems with this either don't use undo, or save the rom often. We've fixed it for ROM Editor V3
Doug, when is V3 available?
Thanks,
JT
ROM Editor V3
Hondata is more than just one person.
We're working on the next release as much as time allows, and hope to have it available by the end of the month (it seems to have been that way all year, but it is getting very close to release now, honest).
Farnsrocket
Post by Farnsrocket »
Has anyone figured out anything else to fix this? At times I can make changes to fuel values, but not real specific changes....it's just random. I have version 2.5 and can't upgrade unless I go to s200. Argh!!
