TPS Problems
Anointeddc5
TPS Problems
I am having issues with my TPS. At idle it reads 0% but at WOT it only reads 98% what do I need to do to fix this?
Anointeddc5
Anointeddc5
Well here is the thread I originally posted up http://www.hondata.net/forum/viewtopic.php?t=6150
The car just sputters (loses power) and stays at 6k rpm for about 5-10 secs then shoots past it but gets cut off completely at 7500 rpm. I have a tuner working on my a/f but even with all the changes we make the problem persists in the exact same spots, so I am wondering if it is a mechanical/electrical issue rather than a tuning issue although I know the calibration can be cleaned up quite a bit. I checked the wire harness and all seems fine except for the vtec solenoid looks a little on the melted side would that cause the problem?
Anointeddc5
Well the link I provided had the information you guys requested thats why I posted it up.
Engine setup:
RSX Type-S
k20a2
Greddy Turbo kit w/intercooler
IPS KT1 Cams
Eibach EVS with Ti Retainers
RC 750cc injectors
Walbro 255 Fuel Pump
Stock returnless fuel system
NGK Bkr8iex Plugs
Hondata KPRO ECU
Ground Cables
Engine setup:
RSX Type-S
k20a2
IPS KT1 Cams
RC 750cc injectors
NGK Bkr8iex Plugs
Hondata KPRO ECU
Ground Cables
