VSS ?????
Posted: Fri Jun 29, 2007 8:37 am
by GredonRacing
During datalog reading the VSS sensor reading was correct up to 146 mph but after 146 the sensor reading increaded up to 200 mph but the car wasn't doing 200mph? Anything possible to use to correct the VSS reading past 146 mph.
Thanks!!
Posted: Fri Jun 29, 2007 8:55 am
The ECU speed only will read to 255 kph (157 mph).
Posted: Sat May 09, 2009 11:20 am
by turbogixxer
Hondata wrote:The ECU speed only will read to 255 kph (157 mph).
Is there any way to change this? Reason being, There is a car I am helping out at the track that has nitrous output wired with hondata s300. The car is trapping more 157mph now and it is limiting us by not having the nitrous on.
Posted: Sat May 09, 2009 12:48 pm
If you enter 255 kph / 158 mph then the nitrous will not switch off. We've run it to 234 mh.
Posted: Sat May 09, 2009 1:50 pm
by turbogixxer
Hondata wrote:If you enter 255 kph / 158 mph then the nitrous will not switch off. We've run it to 234 mh.
you mean MPH :p
I will review the logs and CAL to make sure it is staying on, thank you.
