base map?
Posted: Mon Jun 25, 2007 8:27 am
by minnis94vtec
i have a 1997 honda civic dx its a d16y7 it has 8.5:1 comp and 450cc injectors all stock heads metal head gasket a 255 fuel pump t3t4 turbo and a wastegate set at 14.7psi and i will be turning up to 26psi. also it has the fuel rail off a 1994 integra and the holley FPR off it also. it has a custom 3 inch exhaust and a s200 obd1 swap put of the integra also. i just need a base to run off. i have the rom editor and the burner to use. i will get to a tuner shop to get it dialed in
