S300 USb Port bad.
B18c1turboedeg
S300 USb Port bad.
Post by B18c1turboedeg »
I have been hsving a problem with my s300. Last year it worked perfect, the car sat all winter for rebuild and i started having problems with it after i got running again.
i would try to start the car and the red light would be on causing the car to be hard to start. But when i plug the USB cable into the Ecu it will go to green and the car will start right up, but when i unplug it the car throws a check engine light and runs like crap again.
What could be the problem? The socketing is fine, a friend did it, then i sent it to hondata becasue of problems that was 2 years ago.
Also i took the board off ecu and the soliders look good still on the back of te s300!
ITR 1102
Post by ITR 1102 »
have you tried updating your S300 software and then reloading the calibration?
Have you tried the ecu in another vehicle?
B18c1turboedeg
ITR 1102 wrote:have you tried updating your S300 software and then reloading the calibration?
Yes, dont work still !
yup same problem, its the s300.We switched out the s300 for another one and it runs fine, we put mine back in and we ahve the same problem!
I have updates the firmware and all recently.
ITR 1102
Post by ITR 1102 »
Was the problem present before the firmware update?
If it was after the update, perhaps you need to reinstall the firmware in case there was an error or corrupted file during the install. I saw a thread with someone having that problem.
B18c1turboedeg
ITR 1102 wrote:Was the problem present before the firmware update?
No it wasnt present before the firmware update, but i have used 3 laptops in my car and each one keep updating the firmware when i first connect it too the laptop and s300. After i updated the firmware , i took the car to get tuned and we where having the same problem so i had too tune on a borrowed s300.
its funny becasue sometimes when i plug the cable in, i have to wiggle it a little and it clicks off and goes green, but we looked inside and everything is fine
ITR 1102
Post by ITR 1102 »
Spunkster wrote:Rather than loading your old calibration, first try going to File, New and loading a stock calibration and then letting the firmware update. IF this works, just upload your calibration after the firmware updates.
Try this, it worked for someone else
make sure you are not datalogging when it goes to update the firmware
B18c1turboedeg
After i downloaded the new version of the Hondata software, before i could load a new map it stated that the Firm ware need to be up dated, so i would let it up date.
Then i loaded my map on there, in the other 3 s300 i have used i didnt have any problems updating the firmware or anything, i did it the same way.
How much does hondata charge to look at it?
