thudreem
Post
by thudreem »
How much boost are you guys building on the 2 step?
Also what settings are you running?
jew
Post
by jew »
i build 10 psi with these settings
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
this is on a d16y8 with a turbonetics t3/t4 ball bearing turbo
thudreem
Post
by thudreem »
jew wrote:i build 10 psi with these settings
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
DO you know if the spring in the wastegate and what you have the boost controller set at have a factor in how much boost you can build on the 2 step?
kesnut
Post
by kesnut »
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
do you mind telling me what your timing is (in the map table) that your building boost in.
thudreem
Post
by thudreem »
I played with the launch control and can now build 11 lbs with
limiter 7000rpms
activation 6000rpms
fuel 0
timing -10
turbotypeR
Post
by turbotypeR »
mine makes abour 9psi at 7600rpm.fuel and timing are at 0
92 civic Si
best et:9.43best mph:164
thudreem
Post
by thudreem »
turbotypeR wrote:mine makes abour 9psi at 7600rpm.fuel and timing are at 0
Does your car pop and crack, shoot flames out the exhaust when the launch control is on like shot guns going off?
jew
Post
by jew »
thudreem wrote:turbotypeR wrote:mine makes abour 9psi at 7600rpm.fuel and timing are at 0
yeah its supposed to do that cause you're dumping a bunch of fuel out the exhaust.
jew
Post
by jew »
kesnut wrote:jew wrote:i build 10 psi with these settings
limiter 5000rpms
activation 4500rpms
fuel 30
timing -30
sorry it took so long to reply, i haven't been back to the site in a few days. i'll get a screenshot of my timing maps up for you tomorrow or friday.
- Site Admin
Post
by Spunkster »
no screenshots....post your calibrations and datalogs
Upperguy
Post
by Upperguy »
any more info i have yet to use this feature i have msd 2 step now but would love to build good boost so i dont bog
turbotypeR
Post
by turbotypeR »
no it does not.once you start retarding the timing it will
92 civic Si
turbotypeR
Post
by turbotypeR »
no it does not.
92 civic Si
turbotypeR
Post
by turbotypeR »
no it does not.usually you don't see that until you start retarding the timing
92 civic Si
turbotypeR
Post
by turbotypeR »
92 civic Si
