B18C BOOST AND TUNING ISSUES
i got a greddy kit with a td05 -20g, crower stage 2 cams, pistons, rods, etc. question is, with rc 440 injectors, what should be my boost limit? also what should my egt temp look like at full boost, idle, and cruise. i have the stage 3b
95gsrturbo
im not a tuner but from my exp , depending on your compression you should not exceed 280-300 max whp, because you did not sleeve the block, the injectors seem to be sufficient for your power goals and should support 11psi, maybe 13 max i would dare to say dont go over that.
my egt on my hondata does not go over 800 C in vaccuum cruising speed, and in boost its a bit lower due to xs fuel
95gsrturbo
95gsrturbo
