USDM a3 Calibration on JDM Engine?!
Posted: Thu May 31, 2007 8:10 am
by torqueless
I have the usdm calibration for the a3 toda racing camshafts to be used on the rsx type s. I own a JDM DC5 honda integra type r.
What i want to know is will the cam angle settings on the usdm a3 calibration work the way it should on a jdm engine with the a3 camshafts.
If not can anyone supply me with the JDM calibration for the a3 camshafts by toda racing.
Posted: Thu May 31, 2007 9:56 am
The cam angles are probably goign to be similar, but it is impossible to say until you put it on the dyno to see.
Posted: Fri Jun 01, 2007 6:17 am
by torqueless
Well the issue i face is that there is 1 dyno in Barbados and it is hardly every working. :evil: & since the best way to tune cam angles is via a dyno i need to know for sure.
Posted: Sat Aug 25, 2007 7:13 am
by kesnut
hi from trinidad with a type R, i was playing with the maps last night, the base
and if you use the k20a cold air intake dyno tuned, was a very good base map to start with, we just up the cams by 5 in the last 3 columns and that made 4hp on the powerband. our motor is stock and i must second Spunkster dyno is a MUST.
