05+ K-series Transmission ?s
Posted: Wed May 30, 2007 11:11 pm
First off, Ive read the tech article you guys provided.
http://hondata.com/techk20transmissions.html
Very informative and appreciated.
I have an 03 Ep with a PRB Kpro unit. I currently have the original 5 speed EP3 transmission on my car. I have purchased a low milage 06 si transmission and would like to get it working
Now I get the two methods that dont involved a wiring nightmare.
1a. Swap the cases
or
1b. Tap the speed sensor hole
and
2. Add the speed sensor gear
My Questions are,
1. If I swap cases, do any of the pressed gears on the cases need to be swapped? Or it it as simple as just swapping cases? (Specifically in my case: EP3 case)
I ask this because Ive seen a local Honda mechanic swap Ep3 gearing into a base RSX and destroy the gears.
2. If I choose to tap the speed sensor hole location in the K20Z3 trans, is there a specified number of threads we should aim for, or just the whole way though?
1a. Swap the cases
or
and
My Questions are,
