Fuel Table help
delsolb20
Fuel Table help
Post by delsolb20 »
I need to learn how to set my fuel table but i don?t know how, I tried by selecting the columns and the rev columns and press the plus key (+) and I didn?t see anything change and I have a 440RC injectors
Thanks :cry:
Preccord00
Post by Preccord00 »
goto the fuel table, select which RPM-MAP block you want to adjust, right click and select adjust or CTRL+J. Then adjust as necessary, if you need to adjust multiple blocks at once, highlight them by clicking and dragging over the blocks you wish to adjust.
I highly suggest the use of an AFR to fine-tune your fuel-map, otherwise you're taking shots in the dark and engine damage may occur.
delsolb20
Post by delsolb20 »
Thanks!
I am using the ITB calibration for my b20/v-tec the thing is that is to rich on low rpm and in the high rpm lean that?s why I need to learn to use the tables
