Failed injector
Posted: Mon May 21, 2007 5:39 am
Hi,
I live in the UK and have a 2002 Civic Type-R which recently developed an ECU fault.
It sudenly started running on 3 cyl on my way home from work one day. I suspected a coil pack or plug but discovered it was the injector which was not opperating. On measuring the resistance of the injector coil I found the faulty one to be 3ohm were the others are 12ohm. I replaced the injector with a good one but it still failed to run properly.
I have not been able to find anyone in the UK with experience of repairing the PRA ECU but having done some reserch I suspect the power transistor array STA464C is what has failed.
I cant locate this component anywere in the UK either, if anyone can help me locate one of these components it would be a great help.
Thankyou
Alan
Thankyou
Alan
