Detonation problems
Detonation problems
I wanted to know if there are any settings I have to change to the S300 to turbo at 5,000-6,000 feet of Elevation? I?m having problems boosting. Detonation problems. I started with the B16greddy calibration and I just Detonate. Boosting 3 pounds to start off. My setup is a B18C1 with Integra Type R Pistons (USDM) and skunk2 stage1 camshafts and Integra Type R transmission. Is there a better calibration for me?
Re: Detonation problems
I would think about changing the pistons and cams before you start to boost this motor. The setup you have now is great for N/A but in my opinion not a good one for boosted applications.scoobs187 wrote:I wanted to know if there are any settings I have to change to the S300 to turbo at 5,000-6,000 feet of Elevation? I?m having problems boosting. Detonation problems. I started with the B16greddy calibration and I just Detonate. Boosting 3 pounds to start off. My setup is a B18C1 with Integra Type R Pistons (USDM) and skunk2 stage1 camshafts and Integra Type R transmission. Is there a better calibration for me?
What's the basis? You think the static compression is too high?? or do you think the intake and exhaust duration is too long??thudreem wrote:I would think about changing the pistons and cams before you start to boost this motor. The setup you have now is great for N/A but in my opinion not a good one for boosted applications.scoobs187 wrote:I wanted to know if there are any settings I have to change to the S300 to turbo at 5,000-6,000 feet of Elevation? I?m having problems boosting. Detonation problems. I started with the B16greddy calibration and I just Detonate. Boosting 3 pounds to start off. My setup is a B18C1 with Integra Type R Pistons (USDM) and skunk2 stage1 camshafts and Integra Type R transmission. Is there a better calibration for me?
TurboLS from Team-Integra.net
(703)919-2786 (C)
(703)919-2786 (C)
Well for the data log I can data log but I don?t know how to down load it or watch it I tried. And for the piston and camshaft combination the compression is reduced to almost two points because of elevation. So it should be 10.83:1 at sea level but here at 5600 feet it?s like 9.03:1 or so. So I figured that on 3 pounds of boost I should not have any problems on the p72 calibration. I have been using a P72 calibration but I get full boost at 3000 rpms and I start detonating.
scoobs187 wrote:Well for the data log I can data log but I don?t know how to down load it or watch it I tried.
for onboard datalogging, you set up the parameters to record in the onboard datalogging section of the parameters window. i have mine set to 2000rpms and 50% throttle.
to datalog directly using the smanager software, just start the car up, hook up the ecu via usb cable, load your calibration in smanager and click the button at the top that looks like a lightning bolt. its the 7th button from the left at the top of the window. this will start hondata reading all of your sensor information so you can datalog. to begin recording the data, click the red circle button that's tight next to the lightning bolt one and click it again to stop recording. then you have to save the datalog after you finish recording by clicking datalog at the top of the window and selecting save as.
datalogging will help out a LOT when trying to troubleshoot these types of issues.
I tried to take the plug out it did not work so I decided to pull the B18C1 out of the GSR and take off the head so I can take it to the machine shop that plug is really stuck. So im going to pull the B20 Vtec that I have in my 88 Integra and put it in the GSR, I built it for boost so that should work better and ill just put the B18C1 in the 88.
