k24 reflash for Comptech SC
Posted: Wed May 16, 2007 1:20 am
Dear all!
I have a Comptech supercharger with comptech header and AEM intake on my TSX 04 automatic. Naturally I also have my Hondata reflash.
The issue is as follows:
My engine performs worse than stock. To be precise - it does not provide any power under 3000 RPM - this is even when accellerator is fully pressed. So starting from complete stop is like - very very slow acceleration - then from 3000 upwards the engine is suddenly alive and winds up to 6900 RPM to switch to another gear. Performance between 3000 RPM and 6900 RPM is "so so" - a little better than stock TSX (tested with stock automatic TSXes - I'm only a little better racing against them - and much much worse - when starting from 0 mph).
There is another point - when the car is cold in the morning - and oil temp is less then the usual 11 o'lcock. The 0-3000 RPM range feels VERY different for 5 minutes until oil temp rizes to normal. The power is substancially higher.
Generally - to me - this feels like the computer has not been reflashed (I AM sure that it has been at Hondata).
Questions:
1. What do you think is the problem with my TSX?
2. Would the symptoms be similar if I used the computer without reflash with such a setup?
3. What are your suggestions, thoughts, comments, anything?
4. Everybody is welcome to provide any feedback on their experience with Comptech superchargers / hondata reflash combination.
Questions:
