Help!
5gdxguy
Help!
Post by 5gdxguy »
Okay, this may be a preety simple question, but will the OBD1 wiring harness
from a 94 Civic DX just plug into a b18a1 motor from a 91 Integra LS? The wire harness has gray injector plugs and so does the motor, and I'm tracking down a P75 ecu right now, and want to know if there are any mods that need to be made to the harness, or will i have to change out all the plugs on the motor itself?
Clear taillights add 5-10 HP, don't they?
DaX
Post by DaX »
This is pretty much the setup I'm running. I have a 92 civic hatchback with OBD1 wiring with a 90 LS [B18A1] motor. You'll have to get a grey plug distributor [94+ integra] but for the rest of the stuff it plugs right up. You'll also have to melt off part of the injector plugs to make them connect to the harness, or you can sacrifice some HP and use the injectors from the civic.
5gdxguy
Post by 5gdxguy »
Thanks. I was worried i might have to change all the wiring. By the way my father and I just finished designing our own cable to hydro kit, so pm me if you know anyone who would be interested in purchasing one and saving some serious cash.
DaX
Post by DaX »
Sounds good I'll let you know...I got a HASport kit, but I got over half off the price, cuz a guy I knew had bought a bunch of them and didn't need them anymore.
