couples days ago i got code P0134 a/f primary sensor not activated detected.
i got this code after i switched from PRA k-pro to PRB k-pro for my CTR.
i can clear this error by clearing the dtc's in k manager or restarting the engine . but some times it shows in the next day after i warm the car, some times after couple days.
keep in mind the car runs fantastic , no cels after clearing this one , the a/f sensor is working and reading , am using it now for tuning the parts throttle .
i connected the wires as hondata says .
this code is bothering me .
any help will be appreciated .
thanks
code P0134
ill check the wires today, but the code tells me that the primary sensor is not working , nothing about the heater , i had heater cel be4 (heater not working) and i fixed it .
i read somewhere here in the forum that if the heater is down then the a/f sensor will not work correctly or will not work . will in my case the a/f sensor is working.
this is what happen exactly to me " i start up the car in the morning , the a/f sensor is reading and working , no problem at , after couple minutes while the engine is heating and the engine temp gauge is rising the cel showed up"
another thing , what is the cons of swapping from wideband to narrow band sensor ?? will i get a/f readings ?
thanks
thanks
the code showed again, so i tried to know what is the problem and diagnose it .
but still couldn't solve the problem .
will as i said be4 its not a big problem , but its a lil bet annoying .
so this is what happen exactly .
if i start the car for warming , the a/f ratio will work after few second and its switched to closed loop, i can read it through k-manager, nothing wrong at all, and if i start moving be4 3 exact minutes when the engine temp gauge is raising , there is no code .
i was using the car now for couple weeks with no code .
but yesterday , when i started the car and waited for over 3 minutes, to be exact 3,35 minutes, the cel light came on . i measured it by stopwatch.
i turned off the car again and restarted the engine , same thing after 3 n half minutes the cel light came on.
the problem is that the a/f sensor is working in couple seconds and its changes from open loop/open-cold to closed loop after i started the car, and still work if i move the car just be4 3 minutes , but after 3 minutes n half the cel light popped up.
i am using civic si front o2 sensor part# 36531-PND-A11, i am thinking maybe my problem from the sensor ?
