if i can still use my ECU ??
Posted: Fri May 04, 2007 6:26 pm
by monty
i just bought a s200 and i want to make sure it works fine .. how can i do it cuz the guy use it for boost ... can i take out the S200 from the ecu and plug it in me car to see if it works .. when i open it ,it works burn
Posted: Mon May 07, 2007 9:40 am
Has your ecu been socketed for use with a Hondata system? Have you burned a Hondata rom?
Posted: Tue May 08, 2007 11:22 pm
by monty
yes it its .. and nope i haven't burned it yet ... when i open the ecu to check i notice some burn spot .. but i haven't try to use the ecu yet cuz he said that hes use bigger injectors .. but i only have stock . some how can i make this work ?
Posted: Wed May 09, 2007 10:04 am
Too many unknowns at this point. I wouls suggest taking this to a Hondata dealer to have them look at it and if they say it works, then have them get you a base map for your setup.
Posted: Fri May 11, 2007 1:15 pm
by monty
that sound good . where's the nerest hondata dealer ? im at the valley CA . would you haen to know how much they charge ?
Posted: Fri May 11, 2007 1:22 pm
Posted: Fri May 11, 2007 1:27 pm
by monty
thanks
