s200b Greddy Turbp Base Map Question
Faralon
Post by Faralon »
I'm most likely getting a s200b. I told the guy if it could come pre-loaded with the B16A w/ Greddy Kit base map available from Hondata. He said yes. Then I noticed that the Base map in the Hondata library online uses 440cc injectors. If he edits the map to use 310's will it adjust the fuel/timing accordingly or does all of that have to be re-tuned?
Thanks guys
Maybe there is a Map in the user area that is tuned for 310's?
To run safely you should get larger injectors. The base map can be modified, but will still need to be tuned by a Hondata delaer.
