need a basemap for an ls turbo
Posted: Wed Apr 25, 2007 11:46 pm
by hotazztegra
Have an ls turbo with 450cc, t3/t4 60trim turbo. so if anyone can help me out with a good basemap tune it would be GREAT
Posted: Fri Apr 10, 2009 11:58 pm
by slidns13
any luck with a basemap? im in need of a simualr map..
Posted: Sun May 31, 2009 8:23 am
by BlackDDTeg
Here is my basemap. I run 10psi, and have 440cc injectors. It pulls hard all the way through the power band and the air fuel hit bang on. I did have to run a larger air filter though because I was running rich at full throttle. After I replaced the filter everything worked great. I currently have the launch control set at the recommended setting and I still spin like crazy so you will have to shut it off or lower the RPM to whatever your tires will hold.
