ELD - quick question?
Posted: Mon Apr 23, 2007 11:26 pm
by TransformedBG
I was just curious, what should my ELD read out? Im seeing about 59.77A... i was just curious if that right?
Posted: Tue Apr 24, 2007 8:58 am
Is OBDII enabled?
Posted: Thu Apr 26, 2007 4:24 pm
by TransformedBG
Hondata wrote:Is OBDII enabled?
yeah i had it enabled and disabled. Im just curious if thats right?
Posted: Fri Apr 27, 2007 8:55 am
Enabled and disabled sounds like Schrodinger's cat.
If OBDII is disabled then do not expect to see a meaningful reading from the ELD.
If OBDII is enabled and you see 59A then either the vehicle or ECU has a problem.
Either way it is not critical.
Posted: Fri Apr 27, 2007 9:43 am
by Razathorn
Can one datalog ELD voltage for an external wideband with OBDII disabled?
Posted: Sun Apr 29, 2007 10:51 pm
by TransformedBG
Hondata wrote:..If OBDII is enabled and you see 59A then either the vehicle or ECU has a problem.
umm if its the ECU, then wouldtn that be a critical problem? or would it effect how the car is charging?
