why im getting a knock sensor ..code 24
Posted: Mon Apr 23, 2007 5:05 pm
by monty
ok i have a LS/Vtec with hondata S300 NA motor with couple of mods on it ... now i got the s300 use so i re-calibrate using what it have .. so i put in a stock ITR calibration on it for now cause dont have the money to tune the car .. but for some reason im still geting a knock sensor light code 24 .. WHY ? bad motor of what ? please help ..
knock sensor
Posted: Tue Apr 24, 2007 8:20 am
by Solido78
Go to the parameters and select misc. and disable the knock sensor.
Posted: Tue Apr 24, 2007 9:57 am
What ecu are you using?
KNOCK SENSOR
Posted: Tue Apr 24, 2007 8:58 pm
by Solido78
TRY THE STOCK P61 PROGRAM.
Posted: Tue Apr 24, 2007 11:22 pm
by monty
well im using a P72 with S300 .. im try the stock p61 c what happen .. but i notice that i only get it the light when the motor is aroung 195F temp coolant ... thanks
Posted: Wed Apr 25, 2007 9:31 am
Are you sure you have a knock sensor connected to the block? Do you have the knock sensor wiring connected? Post a picture of the inside of your ecu.
Posted: Wed Apr 25, 2007 6:17 pm
by monty
well this going to sound stupid but where is the knock sensor located ? to see if its on ... ill try to get some pictures tonyt .. and i try to datalog and record it but it doesn't work .. but its datalogging just not recording ..
knock
Posted: Wed Apr 25, 2007 9:23 pm
by Solido78
If you have B18A or B18B block not use knock sensor.
Posted: Wed Apr 25, 2007 9:39 pm
by monty
well that could be my problem would that be a problem in a long run for me ? cause im starting to hear noises like a a screpping metal to metal
