s200 for european version
_JJ_
Post by _JJ_ »
I have a Civic which made in 1998, 3 door, SiR (EK4) with a B16A2 engine. The car is a european version. Can I choose any s200, which will working well in my car?
Javier
Re: s200 for european version
Post by Javier »
It all depends what kind of ECU you are planning to use if you don't have one maybe your best choose is going with one of are obd1 p28 with a obd2-b connector, that ECU will allow you to use a s200 or s100 for you vehicle.
ce
Post by ce »
_JJ_ wrote:I have a Civic which made in 1998, 3 door, SiR (EK4) with a B16A2 engine. The car is a european version. Can I choose any s200, which will working well in my car?
If it's 1998 it's a OBD2 car..You have to downgrade to OBD1..You can use the same ECU as I have in my EG6 (P30-G00)..Btw,I can program it for you :wink: (I got a full system)
K is king
