Ignition skipping in low rpm
Posted: Thu Apr 12, 2007 11:20 am
yes, i have had my kpro for over 2 years now and am very pleased with its performance. however i noticed for about a year now that during first and second and alittle in third there seems to be a slight drop in ignition at low rpm. most noticably in first gear.
Say if my ignition is set at 14 degrees when i hit 2000 rpm the ignition will drop to 9 deg until 2300 then back up to 15 and so on, then at 3000 will drop back down to 10deg for a split sec then back to regular. it is mild when you are driving. and i have ignored it for a year. but i think it needs to be addressed now becuase i have tried everything to get rid of it. it feels as if the ign maps are not smooth. but they are.
my tip in value is set at -100. i was thinking it is the cold ignition retard function malfunctioning.
thanks for the help hondata.
