Help with Problem with oil Presure
jjcr2011
Post by jjcr2011 »
Hello. I have a Swap in EG6. Block K24A4, Pistons, connecting rods, Ciguenal stock, Head K20PRB Sprocker Cams Valve PRB, Pump Oil RSX 2003 Type S.I have the following problem, the oil pressure in Loss is 10. It wanted that they indicated to me if it is a normal pressure or that she is what this happening. Since in Motors Series B It is very different the pressures. Thank You 8)
