Datalogging external knock sensor (detalarm )
Posted: Thu Apr 05, 2007 12:48 am
by jordancivic
Hi, im using a P06 vtec converted, with an external Knock display and a Bosch sensor http://www.roojai.co.uk/products.htm
I would like to connect the signal line in parrallel to an input on the ecu for datalogging the knock. I realise that the P06 doesnt have knock capabilities but i should be able to use a spare input right??
Any ideas?
Posted: Thu Apr 05, 2007 12:52 am
by jordancivic
The 2 signal wires coming from the sensor are signal + and signal -.
Does anyone know the voltage range, or if its possible to datalog? I was expecting 1, 0-5v signal wire.
Posted: Thu Apr 05, 2007 9:47 am
No, you cannot do this. If you want knock control you must use a P30, P61 or P72 ecu.
Posted: Fri Apr 06, 2007 10:26 pm
by Jaker
It does not sound like he wants to use knock control. He simply wants to datalog any knock that the knock sensor detects. It all depends on the output of the knock sensor system you're using. If its within the parameters that the analog input on the P06 operates, then it should be able to datalog no problem.
Posted: Sat Apr 07, 2007 12:35 am
by jordancivic
Thats correct, im not interested in using knock control, only datalogging activity alongside rpm, load etc.
Ill see if i can find out the signal ranges and post detials.
Posted: Fri Aug 03, 2007 4:46 am
by roojai
Best thing is to connect a wire from the signal input into the chip within the Detalarm. This input is a linear signal that ranges from 0v to 1.25v depending on levels of detonation. If you email me I can give you more info on which pin to attach the wire from.
roojai@hotmail.com
Posted: Fri Aug 03, 2007 5:17 am
by jordancivic
Excellent, thanks mate.
What would be the best way to setup hondata for this 0-1.25v sweep ?
Posted: Fri Aug 03, 2007 8:03 am
by roojai
jordancivic wrote:Excellent, thanks mate.
Sorry, no idea as I have no experience of Hondata - just thought I could help with the Detalarm output.
