Hi, im using a P06 vtec converted, with an external Knock display and a Bosch sensor http://www.roojai.co.uk/products.htm
I would like to connect the signal line in parrallel to an input on the ecu for datalogging the knock. I realise that the P06 doesnt have knock capabilities but i should be able to use a spare input right??
Any ideas?
Datalogging external knock sensor (detalarm )
jordancivic
jordancivic
It does not sound like he wants to use knock control. He simply wants to datalog any knock that the knock sensor detects. It all depends on the output of the knock sensor system you're using. If its within the parameters that the analog input on the P06 operates, then it should be able to datalog no problem.
jordancivic
Best thing is to connect a wire from the signal input into the chip within the Detalarm. This input is a linear signal that ranges from 0v to 1.25v depending on levels of detonation. If you email me I can give you more info on which pin to attach the wire from.
roojai@hotmail.com
roojai@hotmail.com
jordancivic
