New to Hondata
Posted: Wed Apr 04, 2007 11:20 pm
by bigbadboy
just got my s300. new to hondata so i have a few questions. i want to run high/ low boost off the AC switch.
wat do i have to do to make it work like that?? thanks
Posted: Thu Apr 05, 2007 5:54 pm
by bigbadboy
any one got any help for me?
Posted: Fri Apr 06, 2007 10:03 am
You have to use the Nitrous/AUX parameters for this.
Posted: Fri Apr 06, 2007 12:36 pm
by Shmaa
Spunkster wrote:You have to use the Nitrous/AUX parameters for this.
What?
Posted: Fri Apr 06, 2007 9:55 pm
by bigbadboy
ok so how exactly would that work??
Posted: Mon Apr 09, 2007 9:46 am
Use a dual stage boost controller that has a switch to togle from the 2 settings and use the nitrous/aux controls to setup the conditions and parameters you want for this. Then use the output to trigger the boost controller.
Posted: Wed Apr 18, 2007 9:20 pm
by bigbadboy
but i'm going to be using a apexi boost selenoid
Posted: Thu Apr 19, 2007 9:33 am
If you are using a boost control solenoid, then you just go into the Boost Control parameters and set it up.
Posted: Thu Apr 19, 2007 8:26 pm
by bigbadboy
ok so all i have to do is set the high/low boost to active with the ac switch?? i tried to set the ac switch to turn on and off my dataloging but it didn't work. so i'm thinking there is a little more work involved in making it work properly
Posted: Fri Apr 20, 2007 9:36 am
You have to wire a switch to the input you are using.
Posted: Fri Apr 20, 2007 9:33 pm
by bigbadboy
yeea i want to use the actual switch for the ac.
