I have a WB o2 sensor installed on my exhaust and am thinking of using it for data-logging purposes. Can anyone tell me how I can set this up?
1. Hook it up to the ELD Pin? where is this located? I found some documentation in the S100 section but those were meant as a replacement to the NB o2 sensors.
2. Then probably tick 'Datalog ELD Voltage' in closed loop parameter
3. Choose WB sensor and set voltage to AF values under settings.
Is this right?
Thanks.
Datalogging with external WB sensor
Read that but it looks like that is meant for replacing the stock o2 sensor vs wiring up an extra o2 sensor?
Or should I be following this portion:
Method #1 Closed/Open Loop - Wideband readings datalogged in S-Manager:
* Red wire Power cables for the PLX wideband - connect to switched power in the fuse box
* Black Ground - Attach to solid chassis ground
* White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
* Gray 0-1V Output for narrowband - connect to white wire from stock O2 plug per instructions below
You cannot just wire a wideband sensor into the ecu, it must have it's own separate controler such as the PLX Devices unit.
www.plxdevices.com
www.plxdevices.com
