boost controller help!
Posted: Mon Mar 26, 2007 4:05 pm
by hopupimports
i just installed my greddy kit on my rsx-s, and i hooked the gm solenoid up to the k-pro for a boost controller. well, it works just fine, but when i turn the car off, my oil light, my window switch light, and the check engine light stay on. not all the way, just barely on. then if i unhook the solenoid, they turn off. has anybody had this problem, and how can i fix it? also, if i leave the dome light on, it will start flashing like its giving off a code. i have never heard of this before. this only happens when the car is completely off.
Posted: Tue Mar 27, 2007 9:16 am
Wire the solenoid to switched ignition.
Posted: Tue Mar 27, 2007 1:28 pm
by hopupimports
Hondata wrote:Wire the solenoid to switched ignition.
it is on a switched 12v
Posted: Tue Mar 27, 2007 2:32 pm
For a quick test unplug the solenoid. If the lights go out, then the solenoid is not connected to switched power.
Posted: Thu Mar 29, 2007 4:06 pm
by hopupimports
they do go out. thats whats weird. also, i dont understand why the oil light would be one. it has nothing to do with the oil
Posted: Thu Mar 29, 2007 4:37 pm
What is happening is that the solenoid is supplying power to the rest of the dash when the ignition is out.
With the RSX there is a very good place to get switched power. In the under dash fuse box, check the exposed spade connectors with a multimeter, and find which one is switched ignition power. (Sorry, I have removed the turbo from our RSX so can't tell you which connector it is). Make a wire with a crimp on female connector, plug it in, and away you go.
