Another A/F sensor issue
Posted: Sun Mar 25, 2007 9:41 pm
I have read what I could find on A/F sensor and I think I may have damaged my ECU. My sensor was damaged severely (physical damage) and my cel came on. I replaced with another that had to be spliced (was a honda sensor) and it worked. I then pulled it out and to make it more permanent by soldering the connectors into the original plug. I screwed up and I believe I got the two black wired crossed. Now, it is not working either way and I seen where you said it can/will damaged the ECU.
1) How can I tell if my ECU is damaged?
2) Are all Honda widebands the same? (I can get a junkyard CRV/Accord for cheap but no Si available)
3) How about RSX? Are they the same?
4) Cost of used and or new ECU?
thnx
thnx
