I have read what I could find on A/F sensor and I think I may have damaged my ECU. My sensor was damaged severely (physical damage) and my cel came on. I replaced with another that had to be spliced (was a honda sensor) and it worked. I then pulled it out and to make it more permanent by soldering the connectors into the original plug. I screwed up and I believe I got the two black wired crossed. Now, it is not working either way and I seen where you said it can/will damaged the ECU.
1) How can I tell if my ECU is damaged?
2) Are all Honda widebands the same? (I can get a junkyard CRV/Accord for cheap but no Si available)
3) How about RSX? Are they the same?
4) Cost of used and or new ECU?
thnx
Another A/F sensor issue
You can use sparkplugs.com's online shopping site to check what sensors in what cars are the same ;). Just lookup the 02-04 rsx type-s front sensor part number and then you can look it up on the other cars to see if it's the same. If I recall correctly, the CRV, 02-05 civic si, and 02-04 rsx type-s and base all use the same sensor. I could be wrong however, so do check and or wait for hondata's reply. You can also use estore.honda.com to cross reference sensor part numbers -- it's very handy as well.
Wayne
Wayne
