temp idle compensation
lsturboteg
is there a way to adjust idle speed for temp or a warmup type table?
lsturboteg
Mine idles crazy high too when it's cold. The best thing you can do probably is repeat the idle learn process when the engine is warmed up.lsturboteg wrote:it seems to idle high for a long time, i was just going to see ifi could make that be shorter. thanks for the reply.
crackerjack
idle
up here when its cold in winter -5C to -20C. The idle goes as high as 2000rpm but usually hovers around 1800rpm most of the time.
